Mamie_Otero
Posted on - 11/07/2011
Hello. I am having trouble with my InfoPath.Â
I created a field called the projectlead.Â
I had no trouble at all when I used the expression control.Â
However, when I set the default as projectlead, nothing is displayed.Â
What should I do?
Problem in Infopath form with expression control
Microsoft InfoPath 2010 types may be either Web browser varieties or Sealing material forms. Web browser forms, that are the default kind, are available regarding much a lot for additional consumers to complete, since they may be stuffed enter numerous Net browsers.Â
Nonetheless, not every InfoPath characteristics as well as handles are supported in browser types. Hungarian monetary unit forms assistance the actual complete arranged associated with InfoPath characteristics, yet Microsoft InfoPath Hungarian monetary unit is necessary to fill them out there.Â
When designing a questionnaire, you are able to alter the compatibility setting anytime during the design method. For example, if you began away having a Web browser kind, on the other hand later on make up one's mind which you have to use handles which are not obtainable in a Application kind, it can be transformed to type A Hungarian monetary unit kind. With regard to more info relating to the way to select a kind type, or even modify a questionnaire from one sort to one more.
Regards
Jackson
