Problem with installation of NetApp
Hi friends
Iam unable to install NetApp.
I have installed NetApp but its not working so i would like to remove and reinstall NetApp.
Can any one help me in reinstalling NetApp?
Thanks
Hi friends
Thanks
NetApp offers different products from their web site and I don’t have a clue which of these products and applications is the one you have. It would help us both if you post the name of the application you are using.
But anyway, visit again NetApp web site, and then check there your application’s system requirements so you will know if your computer is compatible with the application.
If there is no incompatibility problem, try to check if the application requires another application before installing like for example, Microsoft .NET Framework or Adobe Flash Player maybe.
You may also try uninstalling the application then check your computer for any possible errors.
Use a disk utility application to check the system. After the disk check, install the application again and see if it works.
