Problem in installing Chessmaster 9000
I am using windows 98 as OS. My system configuration is as follows:
Hard-disk:160 GB
Processor: Dual Core
RAM: 512MB
A few days ago i faced a problem when i was trying to install the program chessmaster 9000. I got a message like this
"Please login with administrator privileges and try again."
I logged in as administrator but the same message is shown. I was unable to install the program. How can i solve this problem? Please Help me.
Best Answer by Morris
Answered By 0 points N/A #127598
Sometimes virus can affect your computer administrator rights but there is no problem it can be resolved easily you just follow these simple steps and an easily install your chessmaster 9000 program. First of all restart your computer and on logon windows press F8 and go to safe mode and after login with safe mode click on start menu click on control panel click on user accounts in user accounts create a new user with administrator rights.
Give a new user and password and save it and restart your commuter after login with new user you computer administrator rights will be on default level now you can install the program and it would be better if you will download or install an antivirus program and run a scan of your PC for viruses.
Answered By 0 points N/A #127600
Sometimes administrator rights can create such problem during install software so use Run as administrator during installation of software. If you again face this problem download latest version of your software and install. It can be cause for virus so make your computer virus free and then install.
I think you will be successful.
Thanks and Regards
Louis
