Problem installing Erwin community edition
Posted on - 06/21/2013
Hi fellows
I have recently downloaded the CA Erwin data modeler but I am not able to install it. Every time I try installing it, I am met with an error. The error says: “C:Users~TempERwinISCustomActions.dll cannot be found”.
The screenshot of the error is attached below:
I have tried installing it on two of my different systems with windows 7 64 bit but unfortunately the same problem occurs.
Please guide me to fix the issue. I'll be really obliged.
Thanking you loads
