chrisstate
1030 points
Posted on - 07/29/2011
Hello friends!
I am posting here an error message I encountered while installing a plugin of Mozilla Firefox. While I was in the middle of installing a plug-in, an error message appeared and told me that Mozilla Firefox was not installed.
Firefox Plugin Install
Mozilla firefox and Opera are not installed.
As I was analyzing on the error, I wondered why the installation of the plug-in did not detect my Mozilla Firefox? So, I restarted my computer hoping to get rid of the error. Same thing happened. I cannot install the plug-in. Please share some pointers for me to use as a guide in solving this issue. Thanks.
Problem installing the Firefox Plugin
What version of Firefox are you using?
jeanne
5 points
The most important thing in installing plug-ins for your Mozilla Firefox is that it must be compatible with the kind of version your Mozilla Firefox have. Some plug-ins are just not compatible with all version of Mozilla Firefox. One thing to keep in mind when installing a plug-in for Mozilla Firefox is to look for a list of compatible versions that it can be installed in. Only then can you install the plug-in when you know that it is compatible with your version.
You can also try to uninstall Mozilla Firefox. There may be some corrupted files in Mozilla Firefox that is keeping you from installing the plug-in. Try using different softwares for uninstalling programs like Revo uninstaller. It will thoroughly clean your PC from the software that you just uninstalled.
I hope have shed some light on the matter.
