Problem installing Virtualbox in Blackbuntu
Hello to all,
I have encountered a problem while installing Virtualbox in Blackbuntu.
The installation started successfully, and it was about to finish but unfortunately an error message popped up on the screen.
The screenshot of the error is attached below:
An error occurred
The following details are provided:
E: virtualbox-ose-dkms: subprocess installed post-installation script returned error
exit status 10
                                           Closed
I tried to install it several times each time ending up in the same problem.
Can anyone suggest a solution please because I am totally new in this stuff.
Anxiously waiting for your suggestions
Thanks and best regards
Harry
