Problem in installing win XP as a partitioned os
I partitioned my disk then inserted XP sp2 and partitioned using boot camp , the file loaded well and after a while it restarted back to initial stage ,
what could be the issue?
You do not require and boot camp for the purpose. Insert the boo table windows XP disk.
1.      The disk will boot up and then a screen appears as to whether you want to install XP.
2.      Finishing all such formalities for a fresh installation, you get the partition page.
3.      Instructions to create and delete partitions are given in the page. Use the keyboard to select one by one drive and
      then, press D for delete and all such keys.
4.      Create new partition using press C on an un partitioned space.
5.      The partition on which you like to install the O S is selected then press enter.
      The installation starts.
