Problem with internet download manager(IDM)
i am using internet download manager when i play any video on YouTube it display a box in which "download this video" is written when i click on that the URL of the video is copied to internet download manger and it start downloading but after 5-10 second it closed by itself and the download remain incomplete. what is this problem and how this problem will be solved
Best Answer by amannan
Answered By 0 points N/A #113463
Hi, your download manager lost it's containing folder to save. I want to said to you that your Internet Download Manager's save file may not enough file to download. It is happening from Low disk space, Another reason you have your Internet connection will be lost after sometime to it's local speed.
1. At first you check out your setting to server time out limited or un limited.
2. Save on which folder you select
3.Your downloading file have legal Mb.
If you select to video file to convert audio setting then it obviously time out after some time.
You have to make the right thing on instruction, If not enough then Re-install it by deleting 'C' drive.
thanks.
Answered By 0 points N/A #113464
I understood well your anxiety and I think that the problem and the solution are in the speed or the debit of your internet connection
It is true that we like downloading files by internet Word pdf, file wave, and video but sometimes the files which we want to download are very voluminous with regard to the speed of our internet connection, for it when you do not manage to download some file it will display a message which says to you that you have to inform your supplier of internet connection and send the report of error to the server by clicking on OK in the message.
