Problem ip serveur crusader king 2
I am playing crusader 2 and I want to use multiplayer. When I try to connect to the server, then it shows problem with my ip. Is it the problem with my internet service provider or the game itself?
I see that you are facing a problem when you try to connect to the server of crusader 2. You could try the following steps:
1. Firstly, check whether your internet connection is working or not. You can do this by opening any website in your web browser. If it is working, there is no problem with the internet service provider.
2. Check the IP address in the game. If it is wrong verify it and restart the game.
3. When you use a WiFi connection to connect to the server the IP address may change due to a lot of devices connected to through the router.
Hope this information helps you.
Notifications
