Problem with iPad in searching
Every time I search in Google photos it says there are no results. Is there any problem with my iPad? Thanks
Have tried clearing Safari’s cache? , you can do this by going to Settings > Safari > Clear Cookies and Data also Clear History.
If that doesn’t work, try closing Safari completely and then re-launch it : from the home screen (i.e not with Safari “open” on-screen) but with double-clicking the home button to bring up the taskbar, then press and hold any of the apps on the taskbar for a couple of seconds or so until they start shaking, then press the “-“ in the top left of the Safari browser to close it, and touch any part of the screen above the taskbar so as to stop the shaking and close the taskbar.
If all else fails, a reset is in order, this is done by pressing and holding both the sleep and home button for around 10 to 15 seconds (don’t do anything with the red slider), afterwards the apple logo should appear (your contents will not get lost or deleted). There you have it your iPad has been rebooted
