Problem Is Occurring While Printing Pdf File Using Acrobat And Acrobat Distiller Error Appears
When the user is working Acrobat distiller and tries to print a pdf file using the application, then due to corrupted files and folders an error occurs that is named as ‘Acrobat distiller error.’ The error code description is ‘Unable to create the temporary folder. Error 5: Access is denied.’ The methods to fix the issue are as follows:
Method 1: Clean the Temp Files for System.
Step 1: Hold Windows key+ R and type the command %temp%, then press Enter.
Step 2: Press and hold the “CTRL” key and ‘A’ at once.
Step 3: Now, hold down the “Shift” key and press Enter.
Step 4: If you get an option, click on “YES” or “OK” to continue the process.
Step 5: If the user gets a prompt message again, check the box to repeat the action and then click on the “Skip” button.
Method 2: Allowing the permission.
Step 1: Open the temp folder.
Step 2: Look for the Acrobat Distiller folder and open it.
Step 3: Create a new folder in it and give all the permission to that folder.
Now, try to open the folder; I hope your error will be resolved.
