Problem with ISO file of a game
Hi Techyv Team ,
I have downloaded an ISO file of a Game.
But, the problem is that, I don’t know what to do with this.
I can’t Understand how will I install this Game.
Please, tell me, what is ISO file and what to do with it??
Any help
Thanks
Answered By 0 points N/A #95459
Burn it or either run it by mounting it on virtual drive software.
Burn:
You can burn it using the following burners:
  • Alcohol 120%
  • Magic Iso
  • Power Iso
  • Nero
  • CDBurner XP
Search for the internet on how to bur ISO files using one of this software but I suggest the you use the first software and then see what you prefer.
Virtual Drive or Daemon Tools:
Read it using one of this software:
  • Alcohol 120%
  • Magic Disc – Associated with Magic Iso
  • Power Iso
This are the software that I used when reading or burning image file. I just search it and find it so I think you will not have any trouble following it.
