A problem with izotope ozone 4 once it is installed
Hey techyv,
I recently installed the trial version of izotope ozone 4 that I had downloaded from there website.
Once it installed however, there is no way to start the program as I can not find it on my computer at all.
There is no shortcut on the desktop and I can not find it at "Start/All Programs/izotope".
Best Answer by Randolph Brownlow
Answered By 0 points N/A #172453
Izotope ozone 5 is out and very efficient.I would like to advance go for its trial version and leave alone izotope ozone 4.
Go to this site and you will clearly see it.it has 7 additional components.
Answered By 5 points N/A #172454
Hello Terry
You can not find a launcher for Izotope 4, because it is a plugin.
They run inside the programs which they are installed for. In this case, I'm guessing Winamp.
You will find the plugin inside winamp. However, you can find Izotope installation files inside C:Documents and SettingsUsernameMy DocumentsiZotope Ozone Presets , where username is your username from the computer.
You can also access the Izotope Plugin from the Winamp menu, if this is the software related to. Go to Options > Preferences and in the left you will see Plugins.
From there you can access the Izotope 4 interface.
I hope you will find thins information useful.
Randolph
