Problem With L2230xwa Display Using USB in Windows 7
I got a double L2230 screens, and I need to apply as a double display through USB.
I discover that the USB device from CD situations with more application of Screen 7 like Internet Explorer and 3D max.
Please search fault concept from the picture below.
iexplore.exe-Application Error
The instruction at 0xf6a87404 referenced memory at 0x006EEDC0.
The memory could not be written.
Click on OK to terminate the program
This issue vanishes when I remove the USB device.
Please I want to clarify if this drive's has an issue or if the other USB device is operated in screen 7.
Thank you.
