Problem in LAN connection-Requires frequent Modem Restart
I have got a problem with my Modem, where I have to turn off and turn on every 2 hours for the internet connection. I have checked the IPCONFIG settings with and without internet but couldn’t find any difference. Will removing all third party firewall helps? Is it safe to disable windows firewall and retry? Shall I uninstall and reinstall Ethernet drivers? Shall I buy a modem and Ethernet cables and try again? Shall I do any changes in static or DHCP? If yes, what are the possible things I can do? Please help
