Peter A May
10 points
Posted on - 03/28/2013
Hello, I have purchased Lenovo g560 0679 it's Configuration given below:
1. Operating System: Windows 7 (64-bit)
2. RAM: 4 GB
3. HDD: 320 GB
4. Processor: Dual-Core
Now I told about the problem is after running around 30 minute the cooling fan creates noise for 1-3 minutes then stop. After some time again same problem recycling and it is annoying me much. Is there any way to stop this stupid noise?
Problem with lenovo g560 0679 NoteBook.
Hi Peter A May,
Hope this finds you in good health. Actually the problem you are facing related to the hardware of your purchased Lenovo g560 0679. It's nothing to do with any software. So, you can't stop it until the repair. If the warranty on the laptop is valid immediately taking it to the shop you have purchased or got to the nearest Lenovo servicing centre if any. I am not sure about your locality so I couldn't suggest you any places to go. But immediately repair it or your laptop will be permanently damaged due to excessive heat. You can use a heat absorption pad available in the market for damage limitation.
Thanks & Regards,
DBD
