Problem with Lightning 1.3 and Thunderbird version 11.0.1
I have installed the web application Lightning 1.3 and I’m using it on Thunderbird version 11.0.1. It shows me the status “downloading”. It provides me the .ics file which contains events. I want to import it into some of the calendars like USTA. Here, I get an error message like below-
“Timestamp: 04/10/2012 05:16:06 PM
Warning: There has been an error reading data for calendar: USTA. However, this error is believed to be minor, so the program will attempt to continue. Error code: DUPLICATE_ID. Description: ID already exists for addItem
Error: An error occurred when writing to the calendar USTA! Error code: MODIFICATION_FAILED. Description:
Source File: resource://calendar/modules/calUtils.jsm -> file:///[HIDDEN]/calCalendarManager.js
Line: 1108
This error message appears 5 times more and later on a yellow triangle is seen adjacent to USTA calendar where the tool tips show me the status ‘’The calendar USTA is momentarily unavailable". USTA appears as unavailable to me and it disappears when I go to select it. The .ics file is ok. Can you please help me here.
