hannahwtc
10 points
Posted on - 09/07/2012
I installed Linux mint mouse driver to my computer but I am facing a problem while using it.
The mouse pointer gets frozen after using it for a while.
Can't figure out the problem.
Please give a solution to it.
Problem with linux mint mouse driver
I think you should download and install the Gpointing-Devices-Settings.
After installation, you can change the touch pad configuration from there.
If it does not provide any solution, then try to change the version of the Mint Mouse Driver.
If this step fails, the last way is changing the version of java.
Linux Mint System comes with the default Gnome-2 desktop environment installed on your PC.
I'm going to give you a link that will show you several tips and tricks that are very reliable upon working or using this system.
Since you haven't mention what version of Linux you're having, please let me just inform you that those article are best with Linux Mint 11 and Linux Mint 10 .
But if you're having Linux Mint 13 just please check out the Cinnamon Edition and Mate Edition.Â
