Problem loading files in base station
I have a problem in loading my files from my apple base station. should I copy the file or there is something going wrong with it?Â
You may check the computer for any possible errors. Use a disk utility application to check the system. For a much thorough diagnostics on the system, use a disk utility application like PC Tools Performance Toolkit or Norton Utilities.
Any errors in the hard drive’s file system can cause different sorts of problems in applications. It can also make an installation to go wrong that sometimes lead to an incomplete installation of the product.
If you are accessing your base computer through a Local Area Network (LAN), check the network connection of the base computer as well as its network settings. You may also check your user rights to the base computer if you have full privilege.
