Problem logging in to my laptop
You can have this issue resolved, by try logging in to your windows through Safe Mode, as most of the computers do not require password at safe mode. To do this, follow these steps,
1. Power on your laptop.
2. After initial boot Screen start pressing F8 button 2 3 times and you will enter the boot option screen.
3. Here you can choose the option Boot in Safe Mode.
Once you have logged in Safe Mode, you will have access to almost all of your data and copy it to some external source for further use.
You can use some third party software available. Try the software available in below links. Please read the review and instructions before you use them.
https://www.lifewire.com/offline-nt-password-and-registry-editor-review-2626147
https://www.lifewire.com/pc-login-now-review-2626149
if you are using Windows 7 apart from using above third party tools you can use windows repair utility to reset your password. Follow the tutorial available in below link.
https://www.howtogeek.com/96630/how-to-reset-your-forgotten-windows-password-the-easy-way/
Finally I would like to say use a password that you can remember easily but cannot be guessed by your friends or other people.
