Problem with m2ts cannot render file
Okay. I have a problem with Media Player Classic. What is m2ts file by the way? Media Player Classic displays an error: “cannot render the file”. What’s the meaning of that? Please help. I’m having problem with m2ts cannot render file.
Answered By 0 points N/A #168304
Hello Roya,
M2Ts file is a MPEG-2 video streaming file. Usually windows media player supports opening this type of file. It should start opening just double clicking on it. If not so, it means there is no supporting software installed on your computer.
Try downloading player that can read m2ts files. Moreover, you can convert the file in to another file type by using converting software.
Hint: You may try opening m2ts file in Notepad or another text editing software. Because, some of m2ts files are only text-only files. The text editor may open it properly.
Hope this will help.
