consignvic
10 points
Posted on - 10/31/2011
Hi Everyone ,
I’m having trouble in saving a document to a local folder it says memory is not enough and it saves to other network location. I already set the default save location to local drive. I’m using Office 2003 in my Windows 7 pc. Could please explain why I’m getting these errors every time I try to save? Thanks !
lee hung
75 points
Problem with the Memory Why ???
Hello Consignvic,
It seems like your local primary hard drive is full and you will need to remove some files from it, empty those that you do not need and save or backup the important ones that you need in an external hard drive. It is recommended that you do not keep a lot of files on the drive that has the operating system because it may lead to slowing down your system
Another thing you will be supposed is run disk clean up to clear all unused files, queued errors, caches and other less useful files that may be crowding your primary hard drive.
Hope this helps.
__
Regards
Lee Hung
