Problem with Merge Centre VBA Codes?
10 points
Posted on - 04/25/2013
Good Day Experts!
I need your help in creating my Merge Centre VBA program. Can you share the sample codes of your program? I need to create a short, simple but efficient Merge Centre program using VB 6.0 or VB .Net. If you're a Visual Basic expert then I need your expertise. Please share some of your knowledge.
Thank you so much,
Alison
