ladyj4
Posted on - 02/22/2012
Anyone can help me solve out this error?
I usually got this Error Code 10 and I've been having the same problem.
With some investigations, I tried uninstalling and reinstalling the driver,but it still brought me with the same problem.
If anyone can figure this problem out it will be greatly appreciated.
It was like this:
Found New Hardware Wizard
Cannot Start this Hardware
There was a problem installing this hardware:
nVidia WDM Video Capture(universal)
This device cannot start. (Code 10)
Click Finish to start a troubleshooter that can help you resolve
the problem.
Back Finish Cancel
Problem: Message Error Code 10
Dear brother you should read these lessons to ended occur this conundrum.
1. Likely Errors** Here are the miscalculation codes you are likely to think it over with CD/DVD drives: **Error Code 10 – This device is either not bestow, not working by the book, or does not be inflicted with all the drivers installed. Code 19 Your registry might be degraded. **Error Code 31 – The device is not working by the book since Windows cannot load the drivers vital pro this device.
Error Code 32 (or Code 31)- A driver pro this device was not vital, and has been disabled. **Error Code 39 – Windows cannot load the device driver pro this hardware. The driver could be degraded or missing. **Error Code 41 – Windows successfully loaded the device driver pro this hardware but cannot discover the hardware device.
2. Upper and Lower Filter Removal** About 40% of the calculate, Device Manager CD/DVD drive miscalculation codes are resolved by uninstalling the high and decrease filters.
The filters are drivers the CD-ROM aid to provide service. Sometimes as software is uninstalled like all through an OS upgrade, the registry filter setting will be missing behind even though the registry driver thumbs down longer exists. This causes an miscalculation.
Third have fun burning software will need to be reinstalled with fixing the miscalculation. See Microsoft's article on the theme on how to effect this straightforward Registry exchange: https://support.microsoft.com/en-us/help/314060/your-cd-or-dvd-drive-is-not-recognized-by-windows-or-other-programs. The statistics occur from the experience of my company, Digital Support Tech: https://www.techyv.com/.
3. Applets pro Removing the Upper and Lower Filters** The curriculum XP_CD-DVD-Fix.Exe (based on the registry gather in a line CDGONE.Reg, accomplishes the filters deleting mentioned higher than along with removing a hardly any other keys with the intention of are normally around with an uninstallation of grown-up Easy compact disk creator versions, which is the biggest cause of this miscalculation.
Even if your conundrum is due to uninstallation of a further compact disk correlated curriculum, or an OS upgrade, this scrap must still sort out the trick.
4. Additional Filter Removal** It's furthermore doable here are subkeys which contain the high and decrease filters. See this article, in this area deleting them. This is a reduced amount of ordinary.
5. SONYBMG Rootkit Uninstall** Another strong likelihood is the Sony Rootkit has been installed. The $sys$crater filter with the intention of grown-up Sony composition CDs add to the registry often get on to the drives malfunction and disappear from the gather in a line administrator. Uninstall it with Sony's Rootkit uninstaller helpfulness.
6. Drives Disappear After You install iTunes or Norton Ghost** If with installing iTunes or Norton Ghost, you make Device Manager miscalculation code, try locating the Audio File System (AFS) driver from Oak Technologies by C:WindowsSystem32Driversafs.Sys or responsibility a search pro it.
Rename it afs.Sys.Txt and reboot. This driver is ill-assorted with the driver found in iTunes and Norton Ghost. The driver from these two companies is the same and made by a third company called Gear Software.
After renaming the afs.Sys driver gather in a line you will lose access to the compact disk burning figure of the following: HP Memories Disc Creator, Liquid Audio Portal Player, Oak Technology SimpliCD, or Broderbund's Print Shop version 20.
If you still fancy to aid the burning figure in one of with the intention of software, upgrade it to a Vista versions. For more in rank, think it over the article at this time
7. Cdrom.Inf File Corruption** The C:WindowsINFcdrom.Inf gather in a line is the script Windows uses to reinstall it's CD/DVD drive drivers. When you uninstall an optical drive or IDE channel and rescan pro hardware changes, Windows uses this script to recreate the registry settings and top the drive to the proper drivers.
This gather in a line can be converted into corrupt. You can exchange the XP SP2 or SP3 gather in a line (they are identical) with this lone or the Vista SP 1 version with this alone.
8. Detecting and Replacing Corrupt CD/DVD Drive Driver Files** If lone aptly clicks on one compact disk or DVD drive in Device administrator and chooses Properties and at that time Driver tab, you will think it over five or so records listed.
If one of these are degraded, presumably they will produce Device Manager errors. These can be examined by opening a mandate timely and typing in "sfc /scannow" lacking the quotation marks.
You could need to discover the Command Prompt curriculum (cmd.Exe) in the c:windowssystem32 folder everywhere it ordinarily hangs made known and at that time aptly click on it and choosing "Run as an Administrator". If the sfc scannow mandate finds a corrupt compact disk it will in XP, initially look pro a virgin imitation in the the c:windowssystem32dllcache. If the sfc /scannow can't discover the
