Problem with Mountain lion adobe
Hey any one observed any problems using the abode reader plugin in their OS X Mountain lion. I am facing few weird behaviors of the adobe plugin in my system. Are there any problems with adobe reader?
Hallo Johnnie,
Did you make any upgrades lately, or just changes to the Adobe plugin? Because the errors that you are getting are mostly caused by upgrades that result into compatibility issues. To resolve the issue, you will need to do the following:
Hope this helps
Carl
If you are experiencing a problem with your Adobe Reader, try to uninstall and reinstall the program or download the latest version for your operating system. For Mac users, go to Adobe Acrobat Reader DC. Here, select your correct operating system then your desired language. Select the available version for your operating system then download the program.
For Mac, Adobe Reader supports OS X 10.6.4 Snow Leopard, 10.7 Lion, 10.8 Mountain Lion, 10.9 Mavericks, 10.10 Yosemite, 10.11 El Capitan, 10.12 Sierra, 10.13 High Sierra, and 10.14 Mojave. This should fix the problem. Alternatively, you can download and use Foxit Reader. It’s a great PDF reader alternative to Adobe Reader.
Foxit Reader supports OS X 10.9 Mavericks, 10.10 Yosemite, 10.11 El Capitan, 10.12 Sierra, and 10.13 High Sierra. For Windows, it supports Windows 7, Windows 8.x, and Windows 10.
Notifications
