magnuse
Posted on - 11/06/2011
Hello!
Please help me…
Is it possible to copy paste data from word to Publisher?
This is because I have a word document which is bulleted and I want to copy the same in publisher but when I do the bullet points disappear…
what I can do to copy paste the exact document without losing some of the text.
Is it possible kindly advice?
Thank you…
Problem with MS word to Ms Publisher
Hello Magnuse,
For sure you can copy text from a word document to publisher, but then you will have to ensure that you paste the text in a text box in publisher otherwise it will not work.
In your case, I will advice that you remove the bullets before copying the text to publisher. Just highlight all the text that you want to copy and which is bulleted and then in the ms word menu look for the bullets and numbering icon and click on it. The bullets will automatically be removed when you click.
Now copy the text, and then in publisher create a textbox and then paste your text inside the text box.
Hope this helps.
__
Regards
Mahesh Babu
Trevor
If it is just for copying, yes you can. But if it is for the whole format, you can’t copy the formatting from Microsoft word editor to Microsoft Outlook email composition.
Formatting email in outlook was based on html document formatting. Since Microsoft word can create or export a document to an HTML format, you can export your document as html so that the html code for your document can be copied and paste it into your email composition. Just be sure that plain text is disabled and allow html formatting for your emails. Plain text composition does not supporting any kind of formatting.
