Problem with a multimedia keyboard.
I have a multimedia brand new keyboard. I use it with my laptop. But unfortunately it is causing Microsoft out look window come again and again at the time of typing. I tried to solve it but in vain. Please help.
Dear,
I have understood your problem and I have a solution for you. This will resolve the problem completely.
I have added a link which will surely helps you to diagnose the problem. The link has a complete detail of the problem you wants to elaborate.
This will helps to understand why you are facing outlook windows again and again.
Click for more information on how to fix your keyboard
Their maybe a problem that some shortcut key has press from your keyboard.
Or it may be happen that you are using incompatible keyboard. So, from the page you will able to know about the problem.
Hope you got the answer.
Best of luck for your future.
