The problem is with my AMD AVT drivers
The problem is with my AMD AVT drivers. I installed it successfully and found no exceptional message while installing. However, during start up I received an error message. The screenshot of the error message is as under.
Have you any idea for the error message?
Please help.
C:Program FilesAMD AVTbinkdbsync.exe
Windows cannot find ‘C:Program FilesAMD AVTbinkdbsync.exe’. Make sure you typed the name correctly, and the try again.
