Olivia Aust
10 points
Posted on - 10/20/2012
Hi guys,
The problem is with my creative sketching and painting application Krita. While creating an image it has thrown an error message. It has failed to open the file. The screenshot of the error message is as under. How can I get a remedy of this issue? Please help.
Thanks in advance.
Error-Krita
Could not open
/home/aseigo/pix/blogtmp/panel_default_test.png
Hello Olivia,
The problem seems to be with the image that you are trying to open, and therefore you will need to check it and make sure that it has been saved in a format that is supported by Krita. Also check if the problem may be with Krita app itself. You can try editing another application and see it will work.
Nicke
Error message shows that the file you are trying to open is not of the format that you are opening to the program. You can only open the files that are supported to the program. Also check that you have specific filters for the file you are trying to open.
Krita supports the following file formats when filters are available:
Krita Document
PNG Picture
TIFF Picture
PDF Document
JPEG Picture
Nikon NEF Raw Picture
Canon CR2 Raw Picture
Sony SR2 Raw Picture
Canon CRW Raw Picture
Sigma X3F Raw Picture
Kodak KDC Raw Picture
Kodak DCR Raw Picture
OlympusORF Raw Picture
Pentax PEF Raw PictureÂ
Panasonic Raw Picture
Sony SRF Raw Picture
Minolta MRW Raw Picture
OpenDocument Drawing
WMF Picture
KChart Diagramm
Karbon14 Drawing
SVG Picture
Compressed SVG Picture
WordPerfect/DrawPerfect Picture
EPS Picture
PS Document
 OpenEXR high dynamic-range (HDR) image
FujiRAF Raw Picture
 Smith Thompson
