marita mike
Posted on - 11/05/2011
Hi experts ,
My database version is PHPRunner 6 build 9334. I tested it and it looks fine but there was a problem with the add/edit pop up page size. When I click the record icon, the preview box does not appear wholly; I can only see the scrollbars. Instead, I still have to expand it for me to see the whole content. Do I have to change something with the parameters in the PHPRunner or this is just a bug? Thanks
Problem with my database ???
Hello Marita,
The problem may be either way, maybe it is a bug or an error in the settings as you have set them in the parameters
First, I will advice that you try altering the parameter settings, if there was a point that they worked fine, then restore to that point using the undo command and see if the problem will be resolved.
Otherwise go to the back end code for the PHP runner, try compiling the code from there and see if the compiler captures any bugs in the code. If there are any bugs then you will need to rectify them accordingly and then save the changes. Got to the front end and execute the program and see how everything works.
__
Mahesh Babu
