A problem with my dog moving on desktop.
Hello experts,
A problem with my dog moving on desktop. Yesterday when I opened my dell laptop with an operating system of windows 7 starter, it seems like the dog moving structure in my desktop did not show up. Where can I get the setup of my dog moving design so that I will be able to keep it moving again? Thank you.
Best Answer by Kirsten Sosa
Answered By 0 points N/A #175292
Hello Deborah good day and the movement of the dog in your desktop might be either theme that is applied or it may be a swf file and this ends once we end the process of the file which is running so we have to start once again where the file is located as you even set the setting enabling the working at start up of the windows Operating System so that every time you enter you will get the screen with a moving dog as you set.
Thanks
Answered By 60 points N/A #175293
Hi Deborah Hall,
As I have seen so far, many sites and forums discuss with your concern and I think that the best way to find the best solution is to join their discussion. I have attached a site that may help you find the best answer/solution with your concern.
MYTammy: Virtual Desktop Dogs
Hoping that it helps you a lot.
Thanks and more powers.
Answered By 0 points N/A #175294
Hi Deborah, you may be referring to a screensaver wherein a moving picture was being set on your desktop. Following are the steps in order for you to turn on your Screen Saver:
1.      Go to “Start”
2.      Select “ Control Panel”
3.      Type Screen Saver in the search box
4.      Select “Turn Screen Saver On”
5.      Go back to your desktop, your good to go.
If you were using DeskScape, it could have been set to a “pause” mode. All you have to do is to “ close all open browser” then “Right Click your mouse” and select “Resume DeskScape”.
Answered By 0 points N/A #175295
This is a screen saver on your Windows 7 PC.
If you want to check on it, click on Start and then go to Control Panel. Type screen saver on the search field and then click on Change Screen Saver. And then select the dog screen saver from the dialog box and click OK.
If you are having issues on the current dog screen saver, you can download here.
