A problem with my download iPad themes Windows XP.
Hi techyv,
A problem with my download iPad themes Windows Xp. What is the main cause of downloading a theme Windows Xp in an iPad? Is this has to do with compatibility measurements? I don’t know how to deal with iPad, so I better ask you regarding this issue.
Hoping for your help and kind consideration.
Answered By 0 points N/A #168214
Hello Patricial Ferro,
Based from what I understand about your problem, I can give you a few solutions:
– It might be because your theme was not downloaded completely, try downloading the theme again.
– It might be because it is not compatible to your iPad. Try to ask the one who made that theme.
– It might be because the theme is unstable.
– Are you trying to put a Windows XP theme into an iPad? That won't work because it is not compatible.
I'm sorry if this is a bit much. You didn't specify what the error message is or you didn't describe what happens when you use the theme.
Hope this helps.
