Hello experts,
A problem with my download snow effects JavaScript. I downloaded some JavaScript codes from the internet for snow design and want to apply it in my Christmas sale system. A program that will allow the admin or user to encode prices, quantity and item name or code for the product. Can you share some new codes for snow effects?
Thank you.
Hi James,
If you are experiencing a problem in downloading Snow Effect Javascript, stop it using your download manager and do not right click the files. Check also the firewall settings because in some mirror, it is require that the HTTP reference is not block. And for more information, try this site: http://www.softpedia.com/user/help.shtml#troubleshooting
Hope it will help you.
The problem maybe because you downloaded the Javascript codes incompletely. What I mean is, maybe you left out the images or snowflakes that should be included when you download the code. Without the falling images, your script basically is running nothing. If that still doesn't help, try to check the code's disclaimer if there is any or check for any instructions on how to use it.
