I have a problem regarding my MS Excel. An error message is appearing whenever I open my Document. The message is as follows:
"Â 'C:Program FilesExcel Image Assistant.xla' counld not be found.Check the spelling of the file name, and verify that the file location is correct.
If you are trying to open the file from list of most recently used files on the File menu,make sure that the file has not been renamed,moved, or deleted."
Can I have a useful solution to this?
Alvin228
Problem with my Excel document
This problem is due to a behavior that affected the registry key. When you open a file, the Open action entry ends with '%1'. If you edit this line, you will be able to open the file.
To do this:
Go to the Start button and click Run.
In the Open box, choose regedit then press enter. Open this regristry key: HKEY_CLASSES_ROOTExcel.Sheet.8shellOpencommand.
Over to the right pane, click the Default button.
On the Edit menu, choose Modify and remove the '%1' characters on the end.
Click OK and close the registry editor to open your file. You may also want to install all the updates of MS Excel everytime it prompts you to do so.
Trevor
Yes you can have one. TechyV experts are all ready to serve you and share their expertise.
Your problem might be caused by invalid configuration settings. We are not good enough to change the configuration of your Microsoft Office. But you can do fixing it by your own. Just re-install the program to fix the problem encountered.
Doing registry entry fix is a risky action to be performed unless you are expert in this kind of actions. Better to fix it using the installation disk.
Microsoft office will fix errors when re-installation of the application is executed. You will be given an option what kind of installation to perform. Just choose to repair.
My Microsoft excel experiences the following error every time I try opening a document. The error notification I get reads as follows
Does anybody have an Idea on what I can do to solve this?
