Problem in my experiment in SMF 1.1.16
My situation is, I am attempting an experimental launch by introducing the information into SMF 1.1.16 operating regionally on wamp. The objective is I want to observe and comprehend the whole thing earlier then I will create the ultimate choice to shift to SMF, buy web host, and make it run. This indicates that I efficiently brought in the categories_fourms.sql and associates.sql SQL set information files. But when I try to transfer the topics_posts_smf.sql information file, I get the following error:
Any sort of help or suggestion from your end will be very helpful for me. Thank you in advance for your attention.
