Hi to everyone,
A problem with my game line birds for Samsung wave 2. I just got this new game in my Samsung wave 2 mobile phone device when suddenly while opening the game launcher the system crashed and says unable to open .exe file. What should I do to resolve this issue? Do I have to uninstall it to consider the security of my Samsung wave 2?
Your suggestion is very much welcome.
Hi Kristen James,
If you are encountering problems when trying to launch line birds on your Samsung Wave mobile phone, it might be due to a corrupted installation or the version you have downloaded is not compatible with your mobile phone. I advise you to uninstall it from you mobile phone then try downloading a new one. Download it from Android market to make sure you are downloading a legitimate copy. Hope this resolves your problem.
Hello Kristen,
Before going through the possible solution, it could be helpful for you to remember if you had successfully installed the said game. There are some instances that your phone will block an installation, especially if the installer comes from unreliable source, and yet, the launcher or icon still appears on your menu. However, if you did install it correctly, the problem could be the installer or the version of the game that you have. Yes, it would be better to uninstall it and look for the game installer that best suits your cp. By the way, Samsung Wave 2 has a Bada OS and this limits some of the application from running because majority of the apps runs on Andriod.
