Problem with my GeForce GT 440
I’ve recently bought a new graphics card GeForce GT 440. Every time I play 3D games the first problem that I encounter is the game will lag and then there will be a green and sometimes black line on the left screen. I have an updated driver for this which I’ve got directly from NVIDIA web site. I don’t have any problem with my 2 GB RAM. I hope someone can help me regarding this problem.
Best Answer by Ken Mark
Answered By 10 points N/A #110865
After installing brand new experiment with motorist and all sorts of resources recommended through Palit's help.
  1. I turned off from internet.
  2. I un-installed all Nvidia motorists.
  3. Restart.
  4. Run Driver Sweeper to get rid of leftover show car owner form AMD & Nvidia.
  5. Restart regarding second period.
  6. Install fresh toy with individuals type Nvidia 275.27
  7. Restart to finish setting up fresh driver.
Answered By 0 points N/A #110866
I can help you with some trouble shooting steps:
>>Make sure the driver that you have installed for your Nvidia GeForce GT 440 is compatible with your Windows. If you are using a Windows XP operating system, there are chances of such issues.
>>Make sure your computer meets the requirements of the game. Some games need at least 4 GB of RAM and 5 GB of free hard disk space.
>>Check if your Motherboard is compatible with your Graphics card. Manufacturers such as the Asus, Via etc have issues supporting Nvidia.
Just in case if the above troubleshooting steps does not help you, try reinstalling the Nvidia driver onto your computer. You can also contact the Nvidia support to fix the issue.
Thanks and regards,
Skarbos Jay.
