Hello fellows,
A problem with my iPhone msn videochat. I cannot seem to launch the msn video chat in my iPhone mobile device; I know there is something wrong with the installation or the settings. I need a step by step instruction to be followed to fix this issue. Thank you.
Amanda Mitchel.
Hello there,
First of all did you install it correctly? If not uninstall and reinstall it agai properly with all recommended settings. If still the problem persist, download the updated msn from the below given link-
https://www.macupdate.com/app/mac/14200/amsn
Download and install it, this will surely work. I've heard alot about msn videochat issues on iphones, so what I would suggest you is, try a different alternative for video chat if msn keeps on shattering like this. Skype is the best option for video chat. Here's the link if you want to download it-
https://www.skype.com/en/get-skype/
Hope it works for you!
If you are still using Windows Live Messenger on your iPhone, here are some facts you need to know. The iOS version of Windows Live Messenger was introduced in 2010 but has since been discontinued. Businesses use the messenger as a chat client to stay in contact with employees, clients, and other businesses.
In 2012, Microsoft officially retired the app and requested that all users shift to Skype instead, after Microsoft bought it in 2011. Shortly before Microsoft started the change to Skype, Apple removed the Windows Live Messenger app from the App Store. That’s why if you still have the Windows Live Messenger app on your iPhone, you need to uninstall it since it will no longer work.
Alternatively, you can use the following applications as replacement to Windows Live Messenger:
- Facebook Messenger – works with iPhone, iPad, and iPod touch and requires iOS 9 and higher. App is rated 12+ for the following: Infrequent/Mild Cartoon or Fantasy Violence and Infrequent/Mild Simulated Gambling.
- Skype for iPhone – works with iPhone, iPad, and iPod touch and requires iOS 9 and higher. Also rated 12+ for the following: Infrequent/Mild Mature/Suggestive Themes and Infrequent/Mild Sexual Content and Nudity.
