Olivia Aust
10 points
Posted on - 09/27/2012
Hi guys,
The problem is with my KMPlayer. I downloaded the program from the respective site and I installed it successfully. But whenever I tried to play any files with it I got the error message. The screenshot of the error message is given below.
How can I get a remedy of this issue?
The KMPlayer
Access violation at address 01CA10F0. Write of address 01CA10F0.
For Access Code Violation Error message, follow the following steps:
Uninstall KM Player first. (use Windows Installer Cleanup Utility from https://support.microsoft.com/en-us/help/290301)
Then use CC Cleaner to clean up registry entries (http://www.piriform.com/go/ccleaner.com)
Install the program (KM Player) again.
I tried it on my PC and it worked great. Try this, and your issue will be resolved.
Dear Olivia Aust,
This is the solution above is excellent and it should work for you well, I have tried it myself before, but if it does not work for you, I recommend using K-Lite Codec Pack 9.6 Full it is a free media player software can play nearly all formats of video or audio files you will download it on the link below.
http://www.free-codecs.com//www.free-codecs.com/download/k_lite_codec_pack.htm
