Problem with my Microsoft groove
I have a problem with my Microsoft groove which is totally annoying my works. When I try to use or log in my groove it will pop up the MS groove wizard. Which is a disturbance for me. I can't find a way to deactivate this.
Some one please help me with this.
Answered By 590495 points N/A #137461
You should check again the configuration of Microsoft Office Groove and see if you can find an option there to disable the Microsoft Groove Wizard from appearing every time you use the application.
You may also check on other computers if this is how Microsoft Office Groove works. I haven’t used it even before that’s why I can’t say if it really works that way.
You may also try doing a clean installation of the program again. This will fix any corrupted files in the installation and will restore the settings back to default.
Uninstall Microsoft Office Groove from your machine then restart your computer when asked. After booting, check your computer for any possible errors. Use a disk utility application to check the system. Install Microsoft Office Groove again after this and see if something has change.
