Adams Baker
60 points
Posted on - 09/28/2012
Hi guys,
The problem is with my Microsoft Visual Studio while trying to run Windows Metro Style application on my machine.
I tried the same thing several time. Each time it is throwing the error message.
Please help me to solve it.
Thanks in advance.
Unable to activate Windows Metro Style application
‘8352556e-8a1f-4315-bd7b-9a881a6776d9_bvtp4zbn36tgp!App’.
The application cannot be started. Try reinstalling to fix the problem.
Uninstall the application, then go to the application data folder and delete all the traces related to that application you can find. Now open your application in Microsoft Visual Studio, change its name back to the original/previous name after that build your project and debug it. It should now be working without any error.
I have better way to solve this problem. You will have to do some steps then it will work.
1. You have to remove BIN, OBJ, and BLD folders.
2. You need to delete and re-add the reference to “Windows Library for JavaScript 1.0.RC”.
3. Note that who had already replaced the 0.6 references, so I doubt this will make a difference. I am not sure what is the equivalent reference of C#/VB.
4. After doing the whole process your app will work.
Hopefully, you will resolve your issue.
