Problem with my monitor Samsung SyncMaster T27A950
I have a problem with my monitor Samsung SyncMaster T27A950. About one month ago only when I play games or when watch a movie I do not have red color. If anyone knows what can be a problem please help me.
Answered By 0 points N/A #126816
Hello GraceMeng,
To help you with this problem of your Samsung SyncMaster T27A950 it tends to be a hardware problem like graphic card, adapter cable or the monitor itself but we more focus now about the monitor and its cable adapter. Basically to isolate this problem you must have to connect your system unit to another monitor for checking the output or connect the Samsung SyncMaster T27A950 to another system unit. Second you need to re-check the cable adapter connection between the monitor and graphic adapter if it’s screwed well and also don’t forget to check cable or just wiggle the cable a little. If the monitor is really a problem and still under warranty return it to the shop where you purchase the unit
