Ruth Powel
Posted on - 04/06/2012
I’m encountering problem with my Outlook 2007, when I’m trying to install a provider it gives me an error stating that Outlook social connector was not found. How come it keeps on happening when I try to install the provider? What is the main problem? Please help. Thanks!Â
Problem with my MS Outlook 2007
Most often, when you are using MS outlook, if it start to create problem. Note that, if problem occur, there must be happened any of problems when you installed the providers to Outlook express. If you missed any point, only then problems would took place into your system. So you may reinstall MS Outlook express 2007 to your computer. To install a provider to your outlook 2007, follow the process of Microsoft's official website- support.microsoft.com/kb/287532. Here you can find out a detail about provider installation and related solvency to query about MS Outlook’s any of the versions.
For more visit here also-Â Â https://www.plus.net/ or here- http://www.wintuts.com/setup-e-mail-account-Outlook-2007
Hope that, your problem will must be solved. Thanks.
If the outlook social connector is not installed during the first installation, you get this error. Follow these steps to resolve the problem with provider connector settings. Since Microsoft Office 2007 does not contain this feature so first go to Microsoft website and download Microsoft Outlook social connector.
* Ms Outlook 2010 user can do this by following steps.
* Go to control panel and click Programs and Features.
* Select Microsoft Office 2010 and click Change.
* Go to Add or Remove Features and click Continue.
* Go to Microsoft Outlook, click Outlook Add-ins, and select Outlook Social Connector.
* Select Run from My Computer and then click continue.
* Complete the process and restart outlook.
