The problem is with my OBD II scan tools
30 points
Posted on - 10/24/2012
Hi Experts,
The problem is with my OBD II scan tools. I failed to upgrade the tools. However, I had to try four times while installing the same. It was really a painful task. Now, I need to update it. I received an error message while updating the same.
Have you any idea for the issue? Please help.
Thanks in advance.
AWCopiaFile
Can’t upgrade these files:
C:Program Files (x86)Common FilesDimSportDSUPDATEDSUpdate.exe
