Problem with my Packard bell Imedia Help!!!
Hi TechyV Team,
My Packard bell Imedia 1901 desktop displaying F button below the screen with its logo. I tried with open all parts and keep that again but same result. Any idea? Thanks in advance
Hi TechyV Team,
Hallo Jvasquez,
What do you mean that your Packard bell Imedia desktop is displaying the F button below the screen? If what you mean is that the 'F' key is not in its rightful place on the keyboard, then that is a hardware problem which you should have noticed when purchasing Packard bell imedia.
The only way that I think is possible for you to rectify that is to contact the vendor who sold you that gadget and let them repair for you that problem. Or otherwise they will have to replace the device with another one. You can use your warranty to have it repaired or replaced.
Hope this helps.
__
Regards
Mahesh Babu
