hazelwlee
10 points
Posted on - 10/31/2012
Hi Experts,
The problem is with my PowerPoint X running with Panther (10.3.1). While inserting an image from the file it gives an error message. It says, "PowerPoint is having problems getting input from the user ()". However, after clicking on OK it works as usual. Have you any idea for the issue? Please help me to solve it.
Thanks in advance.
There shouldn’t be any compatibility error since Microsoft Office PowerPoint X can run on Mac OS X v10.3 and its earlier versions.
Did you restart the computer and the error message still appears? If yes, run a Disk Utility check.
If you still see the error message, uninstall Microsoft Office PowerPoint X and delete all the corrupted installation files. Once the device prompts you to restart the device, do it. After startup, run again the Disk Utility check and do a clean install of PowerPoint X using the default configuration.Â
