A problem with my screen saver flying logo.
Hello experts,
A problem with my screen saver flying logo. My computer with an operating system of windows vista has a flying logo screen saver. When I open the computer this morning the screen saver was not present in the center of the computer screen, I was just thinking why it has disappeared? Can you give me some steps to follow to bring it back again? Thank you.
Best Answer by Kirsten Sosa
Answered By 0 points N/A #178389
Hello Gregory,
You  might have changed the screen saver options, or someone else might have done it without your knowledge. You will therefore need to go back to the screen saver options and then choose the flying screen saver and make it the default screen saver.
Nicke
Answered By 0 points N/A #178390
Hi Gregory, following are the steps in order for you turn on the screensaver on your Windows Vista computer
1.      Go to “Start”
2.      Select “ Control Panel”
3.      Click “Appearance and Personalization” then select “Screensaver”
4.      It will then show you the list of screensavers that has been installed on your computer. Select the flying logo screensaver that wanted
5.      Click “apply” and hit “Ok”
