g.k.sumon
250 points
Posted on - 12/01/2011
I am running Windows Vista Ultimate. When I opened my task manager, I can only see the programs that are currently running. Aside from that, there is nothing more.
The tabs are missing and other options as well. The active Processes, CPU usage and Physical Memory are also missing. What is causing this? If this is another issue in my registry, how can I fix it?
Please help.
Predator
Problem on my Task Manager
 It’s not deficit, just confusion.
In windows vista task manager has two views. One is proper view that contains all menu and all tabs and second view is display minimal content that described by you with only have limited function.
Do this,
When you want full view that has all menus with All tabs, you want to double click on border of task manager. Task manager will change their view to full view.
When you want to back in minimal view then again double click on task manager’s border. Your task manager change to minimal view.
Hope this help.
