jabez zion
10 points
Posted on - 11/20/2012
I'm having problem with my video streaming player Java mobile. My mobile phone does not support two players. Sometimes the video stops. When I clicked the pause to allow streaming then played again it didn't work.
Problem with my video streaming player java mobile
Hello Jobez,
It will be very helpful in resolving this issue, if you would like to share the exact brand and model number of your mobile phone. Just give it a try by installing J2ME Streaming 1.1, it works almost on every mobile which is Java supported.
Best of luck with the streaming.
This problem is usually associated with the mobile video player your mobile phone is using to stream the online video. And it would also help if you kind of mention the brand of your phone or maybe the model to much better understand the situation of the problem. I’m not sure if there’s a problem with two mobile video player applications being installed on your device.
If they are both compatible with your device then I don’t see why one will not work. Just make sure that only one mobile video player is running. Because if the other one is still running in the background and you opened a different mobile video player, this will have an impact on the memory load of the mobile phone as well as the services they are both using at the same time. Just try running only one mobile video player when playing a streaming video.
