Jamin Ywain
60 points
Posted on - 09/16/2012
Hi Experts,
The problem is with my Windows Mail Spell Checker.
I tried to check spell while composing a mail and found the error message
This language is no longer available for spell checking.
Please select another in the spelling option dialog”.
I have no idea about the error message.
Please help me to fix the problem.
Thanks in advance.
Good day!
It is possible that the error occurred because there was a change in the language selected for spell check. Try restarting Windows Mail, and then click Tools from the menu and then Options. From Options, click the Spelling tab then click the drop down and choose English. Click ok. See if the error occurs again.
I hope this solved your problem. Good luck!
